Veraplus sees it but won’t pair. It just hangs.
I just got the are Revogi smart candle to pair. It actually paired fairly easily. On/off works but color selection doesn’t work.
Mine paired after the 2nd or 3rd try. The color control worked once. Then I get a series of “Can’t Detect Device”.
Still have the same issue. I was able to pair 1 bulb and get the color to work a couple time then the “cant detect the device” Waited 15 min and it work 3 times and changed color then the same error. I was NEVER able to get the second bulb to show up in the add device. I did completely unplug the first one before setting up the second. I was able to see the second one on my iPhone Bluetooth list and my pc Bluetooth list. Anyone else get these to work. It does list them as compatible!!
