Just replaced my Wifi thermostat with a TH8320ZW so i can tie it to Vera. Was wondering if there are remote temp sensors I can use
You want the remote sensors to tie directly into the Honeywell or bring temp readings into Vera so you can write logic involving both the thermostat and the other sensors?
I don’t think the TH8320ZW can accept additional sensors. You can use Z-wave or Neatmo or other temperature sensors with Vera and write complex scenarios via PLEG or Lua…
