Any reason to not upgrade? Simple Vera3 deployment UI5 to UI7
Hi All,
It seems that I am being pushed to make a move to UI7 on my Vera3 due to plugin support (primarily for the Philips Hue) and I would appreciate any feedback from the community.
My setup is very simple:
  • ZWave only (Except for the Hue controller)
  • 40 devices (switches, dimmers, remotes and sockets)
  • I use a ramp up script for gradual illumination
That’s pretty much it. My home has been rock solid for over 5-years and I make changes very infrequently. Wife Acceptance Factor is through the roof so the last thing that I need is for everything to come crashing down after an upgrade.
Thank you in advance.
If it works … do not change!
So your username means “change for better”…
…in which case you probably shouldn’t bother.
Do, however, investigate the use of AltUI as a better interface (unless you’re using that already!)
[quote=“akbooer, post:3, topic:192581”]So your username means “change for better”…
Do, however, investigate the use of AltUI as a better interface (unless you’re using that already!)[/quote]
Good call on the “kaizen” reference :wink:
It’s unfortunate that Ui5 no loner works with my Philips HUE but I’ll definitely look into the AltUI. Thank you for the pointer!
