any one using dimmers with dimmable LED bulbs?
http://www.pharox-led.com/us/index.php/pharox-300/pharox-300-flame.html
Looking at trying these… They have a list of compatible and non compatible dimmers but of course no mention of zwave dimmers.
Or… can anyone recommend a 60w equiv LED dimmable that will work with any zwave dimmers? Prefer something not harsh white, but a bit warmer for living room / TV area use. Currently have a mix of ‘can’ and regular ceiling fixtures with glass cover. However would be open to changing things as long as it doesn’t cost a fortune.
Les
[quote=“Les F, post:1, topic:167961”]http://www.pharox-led.com/us/index.php/pharox-300/pharox-300-flame.html
Les
Hi Les –
I have been experimenting with many of the LED bulbs with the GE/JASCO Lamp Modules. The led bulbs work fine without any problem that I can identify. Dimming works very smoothly, unlike the CF bulbs. I have had a lot of success with this particular Phillips bulb:
http://www.homedepot.com/Philips/h_d1/N-5yc1vZ15b/R-202530170/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Don[/quote]
Thanks!.. wow I had seen that phillips bulb in pop mechanics recently.
How does it really look? Will it throw light just as well from all directions (sitting upright in a lamp, hanging in a can, etc…)
I would just go out and try it, but a quick search shows NO home depot in my area selling that bulb.
I have one that I have been testing for a few weeks now and I really like it. It gives off a very nice light, dims smoothly and is just as bright as a 60w bulb. Don’t let the orange color put you off. I have tried it using three different dimmers and it works in all of them and dims to about 5% before shutting off. All we need now is for the price to drop.
I have been testing an R30 style 9W LED (=60w) from Earthled.com. Bought the 2800k and the light is really nice. I think it has a 165degree beam pattern which floods well from a ceiling can and looks just like a standard R30 bulb from the front.
It dims really well using a Leviton Zwave dimmer. One note of caution-if you use these next to a regular incandescent bulb, they look very similar on full power. When you dim these LED’s, they stay white as opposed to an incandescent which turns quite burnt orange at lower power. So if you replace all of the surrounding bulbs you will see no difference. If not, it will look odd.
Pricing in single piece units is still quite steep. They do have quantity pricing (over 50 units) which drastically brings the price down to “manageable” levels.
PS. This bulb is not yet listed on their site. It’s a new product and I found out about it while inquiring about something else.
[quote=“ballroller, post:5, topic:167961”]I have been testing an R30 style 9W LED (=60w) from Earthled.com. Bought the 2800k and the light is really nice. I think it has a 165degree beam pattern which floods well from a ceiling can and looks just like a standard R30 bulb from the front.
PS. This bulb is not yet listed on their site. It’s a new product and I found out about it while inquiring about something else.[/quote]
This is almost word for word what I would write about these bulbs. I have been replacing the incandescents in my kitchen with these as they burn out. I use the Leviton dimmers as well and they work great. A couple odd things I’ve noticed about them is they reflect things off my granite in great detail on the ceiling…odd but not a deal breaker by a long shot and the other, they do dim down to about 5% then shut off which is very noticeable when the regular bulb dims all the way to 0%.
I have 4 of the EcoSmart A19’s from Home Depot. Tried them with several z-wave and non-zwave dimmers. They appear to have a ‘ringing’ while dimmed at certain levels. My 20 year old son can hear them, but I can’t! It was bad enough I had to take them out.
Also, with three of these bulbs on a non-z-wave Leviton three way dimmer, the remote dimmer did not work correctly as it would not turn them off from the remote location. I wrote this off as being due to not meeting the 40Watt minimum load (only had about 29 Watts for the three). I did test this back and forth with incandescents and it reproduces. The remote switch will turn on but will not dim and will not shut them off. Dimming and on/off work properly at the main switch (with the IR port).
I have the Phillips orange 60w equivalent LED bulbs. I installed one in one of a pair of bedroom lamps, with the other lamp having the old 60w incadescent. At full brightness, I believe most people would have a problem identifying which was which.
The dimming rate is different between the incadescent and the LED, and the light output color is different at lower power (the incadescent gets more yellower than the LED does when dimmed). Not a problem in my opinion, except that you would not want to mix and match incadescent and LED on the same dimmer (I got a second Phillips for the other lamp).
The dimmer is a ZWave lamp module from Intermatic.
I got my bulbs by mail order from Polar Ray in Colorado.
My problem w/ the Philips is the two-fold. First, that orange exterior is hideous and can’t be used without being hidden from sight. Why they would pick that color over white or beige or black is beyond me. Secondly, it is a very much a spot as opposed to a flood which, IMO, the flood is more versatile.
That hideous hue no doubt needs to optically offset whatever color spectrum the actual LED’s are emitting. They are not pretty, to be sure.
I ordered a phillips as well as one of the others mentioned in this thread. Looks like when turned off the phillips looks like a bug light. Looks like all the 60w dimmables are running about $39 right now.
I have two of these bulbs in some of my accent lights behind a kitchen hutch and also behind a planter. I agree 100% that you need to hide the bulb to pass the WAF.
However, the actual light output from them is pretty good for an LED. They dim nicely (I experienced better dimming capability on a Leviton plug-in dimmer than I did on the GE plug in dimmer). To be more specific, on the GE plug in dimmer, the dim level is fine, but as it ramps up / down it can flicker a bit. The Leviton is much smoother ramp.
I also use the EcoSmart floods in my kitchen. They’re nice, especially since I can power all 6 of the lights for less than the cost of what I replaced! Those 120W got really hot in the summer, too. I can’t wait to “feel” the difference in a couple of months!
A+ for Polar Ray - a great company to work with. I’ve ordered many things through them and have not had any issues.
Anyone used these from Lowes? [url=http://dealnews.com/lw/artclick.html?2,454589,1514232]http://dealnews.com/lw/artclick.html?2,454589,1514232[/url]
These 40-watt Utilitech Dimmable LED’s are only $9.98 each according to the flyer I just got in the mail. I’d love to hear some opinions, I’m pondering the switch to LED for some fixtures and also have some GU10 on dimmers I’d like to replace, but these 40-watt models for $10 seem like a deal!
[quote=“myhomeserver, post:13, topic:167961”]Anyone used these from Lowes? [url=http://dealnews.com/lw/artclick.html?2,454589,1514232]http://dealnews.com/lw/artclick.html?2,454589,1514232[/url]
These 40-watt Utilitech Dimmable LED’s are only $9.98 each according to the flyer I just got in the mail. I’d love to hear some opinions, I’m pondering the switch to LED for some fixtures and also have some GU10 on dimmers I’d like to replace, but these 40-watt models for $10 seem like a deal![/quote]
Was in Lowes this afternoon looking for the new hybrid halogen/CFL bulbs (http://news.yahoo.com/s/ygreen/20110419/sc_ygreen/hybridbulbscombinecflandhalogenbulbfeatures_1 and http://pressroom.geconsumerproducts.com/pr/ge/_prv-three-bulbs-in-one-ge-s-hybrid-199673.aspx) and I took a look at the $9.98 LED you’re referencing.
Didn’t care for the 3000K color temperature, I prefer 2700K for my lights. FWIW- I’m not sure, but I think $9.98 may now be the everyday price for this particular LED cause there was one of the “new low price” shelf tags right below the bulbs with the $9.98 price on it. I also noticed some NOS of the same part number and it showed a lower Lumens rating of 450 versus 490 Lumens on the newer packages. So I don’t know if there’s some trickery going on with the Lumens ratings- but there’s two different values for the same part number?
These 40-watt Utilitech Dimmable LED’s are only $9.98 each according to the flyer I just got in the mail. I’d love to hear some opinions, I’m pondering the switch to LED for some fixtures and also have some GU10 on dimmers I’d like to replace, but these 40-watt models for $10 seem like a deal![/quote]I’ll most likely buy one tomorrow and give it a try.
Don’t wait too long… I just hit lowes and bought the last 3. They say warm white, but are not as warm as the Philips ‘yellow bulb’. Haven’t tried them on a wave dimmer yet.
I am using three different Philps LED’s on a Lutron dimmer. The most recent bulbs that I like are the 6E26R20 (Home Depot 6W R20 but only the 7W is listed on Home Depot now).
The others don’t dim very low, these do, but they turn off at almost the end. They are bluer then the halogens I used to use, but I prefer a more white light, and not so yellow, so works for me. They also don’t hum like the other two ones I have do.
I think the dimmer I have is probably less then optimal, but in general I like the Philips so far.
I was also thinking about trying the Pharos 300.
I have a bunch of EcoSmart CREE floods, mostly run by GE/Jasco and ACT Z-wave dimmers.
In general they work great. Far better than the dimmable CFLs ever did.
With this combination, they are extremely sensitive to noisy power. They HATE CFLs, especially ones that are going south. If they are being disturbed, they’ll flicker at certain dim levels. Now that I have mostly all LED lighting, it works pretty smoothly.
The EcoSmart LED bulbs (regular bulbs, I have the in a ceiling fan) from Home Depot have an annoying buzz when being dimmed. No problems like this with the CREE floods.
For those that are using the Leviton, what model? Is it one of these?
RZI06-1LX
VRI06
I am going to try one but not sure which I should go with. Single pole is all I need for now.
I use the VRI06 and VRI10’s. Great dimmers and will take my new PAR30 LED’s almost all the way down (80-90%) before shutting off.
You will notice a big difference in dimming LED’s- we are used to the color going from white to burnt orange in incandescents as they dim down. That will not happen with LED’s and the dimming is not as noticeable because it stays white the entire time. It’s really an odd sensation because we’ve all lived with the orange hue our entire lives. I am still not used to it as I actually enjoyed the color of a dimmed incandescent. It was very warm-the LED’s are not even though mine is rated at 2800k.
I guess it takes getting used to…
