It’s been already discussed in this topic:
http://forum.micasaverde.com/index.php?topic=2119.30
I added TS001 to my setup but it doesn’t show humidity readings.
Hardware: Vera2
Running Version: 1.0.989.
Any thoughts?
Hardware: Vera2
Any thoughts?
Mine works correctly although I don’t have it doing anything other telling me temp and Humidity so I can speak about that.
Does it show up as three devices?
It does but its the parent and the 2 Child devices and thats correct. However I’m using UI4 and they fixed the humidity reading so that it displays correctly.
Thanks.
I’m new on this forum, any clues\links how to install UI4 on my Vera2?
Thanks in advance.
Virginian
Ok, so hopefully you didn’t get too used to UI2 then!
So make sure you have everything backed up in advanced! Once you’ve done this then visit findvera.com/vera2 and follow the steps and it will detect your Vera and prompt you to update.
[quote=“strangely, post:6, topic:166585”]Ok, so hopefully you didn’t get too used to UI2 then!
So make sure you have everything backed up in advanced! Once you’ve done this then visit findvera.com/vera2 and follow the steps and it will detect your Vera and prompt you to update.[/quote]
Thank you. I have a very small setup, and Vera makes daily backups anyway. And what is the exact URL? Neither www.findvera.com/vera2 nor http://findvera.com/vera2 worked for me.
P.S. Just saw heated UI4/UI3/U12 discussions, amaizing…
Why don’t they just fix this TS001 issue in U12, it shouldn’t be a big deal?
Oops sorry I meant http://micasaverde.com/vera2
Thanks!
