I had the program as per below. I took the script mostly off from here but valur of my ‘mEnd’ variable is totally an unexpected figure. I was expecting 15 minutes past sunrise. What am I doing wrong ? any help ?
Quote
LuaTest 1.6
Lua file: /etc/cmh-ludl/luatest.lua
Results
No errors
Runtime: 1.0 ms
Code returned: false
Print output
Timezone: -5 hours
City: Orleans
Latitude: 45.467
Longitude: -75.517
Sunrise: Sun Dec 27 07:41:13 2015
Sunset: Sat Dec 26 16:24:17 2015
mEnd:776
mNow: 790
mStart: 15
Code
1 local pStart = “00:15” – Start of time period
2 local pEndOffset = 15 – End of time period, minutes offset from sunrise
3 local allow = true – true runs scene during period, false blocks it
4 local hS, mS = string.match(pStart,“(%d+)%:(%d+)”)
5 local mStart = (hS * 60) + mS
6 local mEnd = math.floor( (luup.sunrise() % 86400) / 60 ) + pEndOffset
7 local tNow = os.date(“*t”)
8 local mNow = (tNow.hour * 60) + tNow.min
9
10 print(“Timezone: " … luup.timezone … " hours”)
11 print(“City: " … luup.city)
12 print(“Latitude: " … luup.latitude)
13 print(“Longitude: " … luup.longitude)
14 local srtime = os.date(”%c”,luup.sunrise())
15 print(“Sunrise: " … srtime)
16 local sstime = os.date(”%c”,luup.sunset())
17 print("Sunset: " … sstime)
18
19 print (“mEnd:” … mEnd)
20 print ("mNow: " … mNow)
21 print ("mStart: " … mStart)
22
23 if ((mNow >= mStart) and (mNow <= mEnd)) then
24 return true
25 else
26 return false
27 end
28
29
unquote
