I can’t find anything good. I’ve tried everything stocked at the local big box stores. I would prefer a nice 2700k color and ability to Dim. They will be visible on the chandeliers so having half the light occupied by a base isn’t ideal. Anyone have anything they could suggest?
I have tried LEDs in a track-light instead of the original halogen bulbs. The yellower 2700K LEDs do look much warmer than the ice cold white from the 3500K ones. I have one issue with the LEDs on the GEJasco 45606 dimmer. The LED’s can flash at a very low intensity setting. I went back to the halogen bulbs even though they don’t live as long. I console myself that the halogens use about half the watts incandescent bulbs do for the same lumens (light output). Perhaps GE/Jasco will upgrade their 45606 and 45613 dimmers to work better with LEDs, since that’s the future.
Vera2 (1.1.1350, UI4); ACT ZRW113W; GE/Jasco 45600, 45602, 45604, 45605 x3, 45606 x4, 45609 x11, 45614; Hawking HRDS1 x3; Intermatic CA9000 x2; Schlage BE369GR, WCE100; Trane TZEMT400AB32MAA
