True HA, IMHO, is not even here yet, at least not on the cost level we are talking about. True HA would be things “just happen”. There are plenty of people that do that here on the forums, but I believe that while their attempts are great, the sensors needed for really great presence detection in rooms just isn’t there yet. I’m not bashing people for their attempts. They, and myself, are working with what we have and in most cases it in fact works quite well. My hopes is that one day we can have just a “presence” detector that states someone is in a room without them having to carry anything around. I feel as though we are a while away from this type of sensor, so we use what we have to varying degrees of success.
I don’t feel that what Apple is getting into, at this point in time, is HA. I think it’s Home Control.
My Fiance would argue that the other stuff are just “toys” as well. It’s all a perspective issue.
[quote=“gregl, post:62, topic:181409”]MOST of the important devices like dimmers/zwave in wall switches etc still need to be installed by a electrician ( or someone who knows what they are doing )…or locks installed via a locksmith.
Its a big step from plug in gadgets to inwall/professional installed devices which really is what makes HA really good.[/quote]
This is most certainly NOT true. A DIYer could easily install switches/dimmers and locks without the need of a professional. Do they need to be careful? Sure, but it’s not all that hard. Now, if your house isn’t wired with a neutral at the box, it might mean you need to get an electrician to run one for you, but you can most certainly do it yourself and as long as one is careful, do it quite safely.
The same is even more true for locks. There is NO WAY I am calling a locksmith to install my door lock. If I have to have it re-keyed, I will then call them, but installing a z-wave lock is insanely easy.
Bigger hurdle, but money is money. Anyone can spend money if they have it. As I said above, I think MOST people could install locks and switches/dimmers/outlets as long as they follow some simple safety rules. The trickiest part to HA is the programming (true HA where things “just happen”). PLEG, IMHO, makes this possible on the Vera (as close as we can get), but also adds another level of complexity to the system.
If a user is just looking for “motion at X means turn on light Y”, I think it’s fairly simple on the vera and most people could do it. I do think most people are capable of grasping PLEG, but it has a much steeper learning curve. Installing devices seems much easier to me than that.
*I will note that I grew up with a grandfather who I don’t think ever called a professional to do anything, so I learned early that DIY just takes patience, research, and considering safety to get it done. I’ve re-run electrical in my house, run structured wiring, torn down closets and built them back up (equipment room), completely remodeled my back porch, and so on. It’s all a perspective issue. DIY isn’t has hard as some make it out to be. I do agree though that at some point, it’s just easier and faster to hire a professional. While I can do Drywall, I often call someone to do it because I HATE doing the mud and tape
