I just installed 2501 on both my vera and openLuup. I am loving the power meter update. Thank you.
The ALTUI icon though is not working. It is referring back to a github CDN site and somehow failing for me. I have had to make it local and read from my vera and ALTUI instance. Not sure if anyone else is seeing this?
The ALTUI icon though is not working. It is referring back to a github CDN site and somehow failing for me. I have had to make it local and read from my vera and ALTUI instance. Not sure if anyone else is seeing this?[/quote]
The link itself works from outside but somehow neither openLuup nor the vera are getting to it. I am outside right now and will check when I get back. It may indeed be a browser cache issue but I tried on both Chrome and Safari and they were returning no icon.
I just tested both cdn icons and they both work from the direct link but not when used in by the D_ALTUI_UI7.json file. I am not quite sure as to why. In any case, I have modified the file to now pull the file locally so it is not an issue. If others don’t have a problem, then you can probably ignore my ask. I also have a slight preference for locally hosted icon anyway.
