Vera UI7 Fix only for AltAppStore / GitHub SSL error
AltAppStore has now been updated to fix this problem.
For UI7, the fix is:
[ul][li]Remove the existing plugin device.[/li]
[li]Delete all AltAppStore files: [tt]rm /etc/cmh-ludl/AltAppStore[/tt][/li]
[li]Run the code below (the altappstore_install.lua file) in the Lua Test window[/li]
[li]Reload[/li][/ul]
Here’s the code:
-- first-time download and install ofAltAppStore files from GitHub
-- this code should be run on a Vera in the Lua Test Code window
-- 2016.11.16 @akbooer
-- 2018.02.24 upgrade SSL encryption to tls v1.2 after GitHub deprecation of v1 protocol
local x = os.execute
local p = print
p "AltAppStore_install 2018.02.24 @akbooer"
local https = require "ssl.https"
local ltn12 = require "ltn12"
p "getting latest AltAppStore version tar file from GitHub..."
local _, code = https.request{
url = "https://codeload.github.com/akbooer/AltAppStore/tar.gz/master",
sink = ltn12.sink.file(io.open("/tmp/altappstore.tar.gz", "wb")),
protocol = "tlsv1_2",
assert (code == 200, "GitHub download failed with code " .. code)
p "un-zipping download files..."
x "tar -xz -f /tmp/altappstore.tar.gz -C /etc/cmh-ludl/"
x "mv /etc/cmh-ludl/AltAppStore-master/*_* /etc/cmh-ludl/"
p "creating AltAppStore plugin device"
local s,c = luup.inet.wget (table.concat {
"http://127.0.0.1:3480/data_request?id=action",
"&output_format=json",
"&DeviceNum=0",
"&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1",
"&action=CreateDevice",
"&Description=AltAppStore",
"&UpnpDevFilename=D_AltAppStore.xml",
"&UpnpImplFilename=I_AltAppStore.xml",
"&RoomNum=0",
"&Reload=1",
p ("status = " .. (s or '?'))
p ("response = " .. (c or '?'))
p "done!"
And here’s the response that you should get (if you ran this under AltUI, otherwise you won’t see the print output.)
status = 0
response = { "u:CreateDeviceResponse": { "DeviceNum": "145" } }
done!
I’ve tested this on a Vera Edge and used AltAppStore to install a new plugin successfully.
Unfortunately, UI5 does not have a recent enough default openssl library (I think, or possibly LuaSocket / LuaSec) to allow the required tls v1.2 protocol to work. There may be a fix, but I haven’t found it yet.
