I’ve managed to get Altsteon up and running and added a motion sensor using altsteon_cli which seems to be working–when I wave my hand in front of it I generate the following in a terminal session:
[INFO ] [2/1/2014 - 10:16:56] - Broadcast cmd1 = 11 cmd2 = 01
[INFO ] [2/1/2014 - 10:16:56] - 27.8D.A8 is open.
[INFO ] [2/1/2014 - 10:16:57] - Broadcast cmd1 = 11 cmd2 = 01
[INFO ] [2/1/2014 - 10:16:57] - 27.8D.A8 is open.
[INFO ] [2/1/2014 - 10:16:57] - 27.8D.A8 had 0 hops left!
[INFO ] [2/1/2014 - 10:16:57] - Broadcast cmd1 = 06 cmd2 = 00
[INFO ] [2/1/2014 - 10:16:57] - Processing : cmd1 = 06, cmd1 = 01
I’m using an Insteon 2842-222 motion sensor and would just like to set it up to ultimately turn on a light switch. I’ve added the device through UI5 with the following settings:
Device_type: urn:schemas-micasaverde-com:device:MotionSensor:1
Internal ID: 27.8D.A8, 10, 01
Upnp device filename: D_MotionSensor1.xml
Upnp implementation filename: I_InsteonTriggerSensor.xml
Parent device: plm
The device seemed to add correctly, but when I click “arm” I get a “Device not ready” error.
At the top of the Vera UI, I do see the following:
ERROR : Error in lua for scenes and events
plm[9] : Starting Lua Engine
Not sure if this is related.
Any help would be very appreciated–the forums have been great and I’m so glad to have gotten this far!
