Altsteon and X10 controllers?
Greetings
I’m considering upgrading my X10-based lighting control to Vera/Z-Wave on a piece by piece basis. However it looks like Z-wave handheld keypads are currently somewhat lacking in selection and I’d rather not have to buy all new everything at once.
From my research I gather that MCV’s Insteon/X10 support is barebones at best, and I’m better off with Altsteon. That’s no problem. For the record all my hardware is X10- no Insteon stuff anywhere. I did see another way to do this using an X10 modem and a different plugin, I’d consider that too.
My questions:
  1. Altsteon can control X10 devices right? I’m pretty sure it can, just looking for expert confirmation. If not, is there a better way to do this?
  2. Can Altsteon receive X10 commands and act on them (IE trigger a scene)? I’d like to keep using my current control pads as I have lots of them.
  3. If I send an X10 command to directly control a device, will Altsteon/Vera pick that up and update the device status (show it as being on or off) accordingly?
  4. My alarm system can be programmed to send X10 commands when things happen (arm/disarm/etc). Would Vera be able to process these commands in any useful way? (Linking the alarm directly would be inconvenient).
//edit: 5. Am I wasting my time with this? Would I be better off to just scrap all my X10 gear and buy new modules/controllers? There aren’t many Z-Wave handheld keypads of the style I’d like, but there are a handful of Insteon ones that would work and it looks like would work with Altsteon…
Thanks in advance…
