All On/Off
How can I create a “all on” scene and one for “all off” for all lights in my house
Click on the add scene button on the top left of our dasboard.
http://docs2.mios.com/doc.php?language=1&manual=1&platform=2&page=scenes
JOD.
How do you select each lamp so that I click a all on or all off on my phone?
Create a scene - Name it AllOn. On the Command Tab, open each room that has a light in it, check the box, setting to ON and leave it. Exit>Save and a new scene will appear on your dashboard. Run this scene and every light in the rooms you’ve checked will come on.
Reverse the process for an AllOff Scene. Select lights in each affected room, check the device, set to off and leave it. Exit>Save. Running the AllOff Scene will undo the affects of running the AllOn scene.
Depending on your phone O/S, you can access the scenes and run them remotely.
  1. Press the +Add New Scene button at the top of the Dashboard screen.
  2. Goto Commands.
  3. Goto the room where your device is.
  4. Check the device. On / Off
  5. Goto another room for additional devices.
    When you are done adding your devices, click the X in the top right corner which will add the new scene on your dashboard.
  6. Press Save in the top right of your Dashboard.
  7. Press the run button to activate your scene.
    The scene will then appear on your phone, you may need to clear the browser cache first.
JOD.
(@paintguy - I think we just said the same thing)
[quote=“JOD, post:5, topic:166673”]1. Press the +Add New Scene button at the top of the Dashboard screen.
2. Goto Commands.
JOD.[/quote]
JOD, that is great. I was just talking to someone about the lack of real instructions for the noobs (myself included). This is one of the most basic features and it’s not always obvious how to make it work until you actually get in and get your hands dirty, it took me a few tries to get it going when I started too.
Thanks for the Help!
