Apologies if this has been covered before, but I have a Vera scene to shut down a number of lights which I’d like to use in a ‘goodnight’ routine in Alexa. However Alexa doesn’t seem to anything, the scene doesn’t get triggered. Any advice?
Are you able to get the scene to run if you do it manually through the Alexa app?
No I’m not…
Okay then log into home.getvera.com then before you click your controller on the top right of the page there’s a chevron click that then click Alexa Settings. Uncheck the scene that’s problematic and then delete it in the Alexa app, then check it again and a run a discovery. See if the scene works then.
