'AlarmManager::Run callback for alarm' Z-Wave Flood on Heal
Hello All, I was hoping you could tell me how to debug which device goes haywire during the heal.
There are thousands of these errors in the log post heal. Whenever this happens, I need to shutdown the vera for an hour and then it will reboot successfully (without Z-Wave dongle in a bad state errors).
The problem is, there is nothing in the log file line that gives me which device it is. Any ideas how to narrow it down?
01 02/07/14 9:40:50.508 AlarmManager::Run callback for alarm 0xaac378 entry 0x2af4158 type 24 id 4864695 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.511 AlarmManager::Run callback for alarm 0xaac378 entry 0x3301878 type 24 id 4864696 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.513 AlarmManager::Run callback for alarm 0xaac378 entry 0x130ec38 type 24 id 4864697 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.540 AlarmManager::Run callback for alarm 0xaac378 entry 0x2a09458 type 24 id 4864698 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.542 AlarmManager::Run callback for alarm 0xaac378 entry 0x2278420 type 24 id 4864699 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.579 AlarmManager::Run callback for alarm 0xaac378 entry 0x344eaf8 type 24 id 4864700 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.582 AlarmManager::Run callback for alarm 0xaac378 entry 0x14164a8 type 24 id 4864701 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.615 AlarmManager::Run callback for alarm 0xaac378 entry 0x3322b90 type 24 id 4864702 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.618 AlarmManager::Run callback for alarm 0xaac378 entry 0x2a13d58 type 24 id 4864703 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.620 AlarmManager::Run callback for alarm 0xaac378 entry 0x2266180 type 24 id 4864704 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.623 AlarmManager::Run callback for alarm 0xaac378 entry 0x2e87178 type 24 id 4864705 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.647 AlarmManager::Run callback for alarm 0xaac378 entry 0x3322788 type 24 id 4864706 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.650 AlarmManager::Run callback for alarm 0xaac378 entry 0x285d1b0 type 24 id 4864707 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.652 AlarmManager::Run callback for alarm 0xaac378 entry 0x2a684e0 type 24 id 4864708 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.676 AlarmManager::Run callback for alarm 0xaac378 entry 0x331a5b0 type 24 id 4864709 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.679 AlarmManager::Run callback for alarm 0xaac378 entry 0x286e010 type 24 id 4864710 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.682 AlarmManager::Run callback for alarm 0xaac378 entry 0x2bded00 type 24 id 4864711 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.705 AlarmManager::Run callback for alarm 0xaac378 entry 0x27347a8 type 24 id 4864712 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.707 AlarmManager::Run callback for alarm 0xaac378 entry 0x2fa6a40 type 24 id 4864713 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
01 02/07/14 9:40:50.710 AlarmManager::Run callback for alarm 0xaac378 entry 0x2127388 type 24 id 4864714 param=(nil) entry->when: 1391794845 time: 1391794850 tnum: 1 slow 0 tardy 5 <0x2b351680>
This was traced to the Shock, Vibration & Glass Break Sensor purchased on Vera’s website.
http://shop.getvera.com/ProductDetails.asp?ProductCode=VSN-ZS5101US
I’ve returning all 9 of them ordered as they will periodically flood your Z-Wave network during a nightly heal.
PS - This is what the flood looks like when the Vera can figure out what device is flooding (vs the log above where the node/device ID is not present) that allowed me to narrow down on the Vision Shock/Vibration sensors causing me to return them:
02 03/03/14 9:02:09.858 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:09.898 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:09.938 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:09.978 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.108 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.148 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.188 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.228 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.268 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.308 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.348 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.388 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.428 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.468 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.508 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.548 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.588 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.628 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.668 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.708 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.748 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.788 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.828 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.868 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.908 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.948 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
02 03/03/14 9:02:10.988 ZWaveNode::HandlePollUpdate_Alarm node 39 device 21 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: (null) <0x2c053680>
