Affordable Electric Curtain Tracks - Z-wave integration
If it is not possible to purchase the NWD Z-wave motor?
I am wondering if the Dooya DT52E (Zig-bee) motor could be used with the Duwi blind module ?
The first image below shows Dry Contact wiring, could these be wired in to a Z-wave blind control module ?
The second image is the Z-wave duwi module wiring for 230v motors.
In this setup you would have the Dooya RF (Zig-bee) hand held remote control and possibly the Dooya wall controller as well. And then hard wire a Z-wave blind module in to the wall and connect to the DT52E motors dry contact for Home Automation control via Vera.
Any thoughts ?
EDIT: Duwi-Module-Wiring.jpg is from the Duwi user manual i.e. not the Z-wave.me version.
Trying to consolidate some of this information, I have added a table .doc to the first post here.
I am currently talking to technical at HC China Limited, hopefully they are working out a HT-100 system / solution for me.
My requirements are:
230V Curtain Motor - Can be hard wired in to the wall / house electrics. (I don’t like the idea of having to plug-in a DC power adapter with cables visible.)
Hand held Remote Control - IR (Infra-Red) preferred, so I can program my Logitech Harmony universal remote controls to open / close curtains.
3rd Party Home Automation Control - Need to be able to wire in the Z-wave blind control module. I will then be able to automate the curtains using VeraLite.
Single curtain track / Center opening curtains / Motor on the left / Wall mount brakets
Optional:
Wall Controller - I may not need a wall controller from them. Because if we can integrate the Z-wave module I can use my existing Z-wave wall controllers to open / close the curtains.
Note: Although there is a HT-100 wall controller with in-built IR. If I use this I will not put a paddle switch cover on the Duwi blind module and would instead hide the Duwi blind module in a back-box inside the wall.
Sent NWD a second inquiry directly via email.
If I don’t get a response again - I will scratch that company… :-X
[quote=“frichter09, post:64, topic:173020”]Sent NWD a second inquiry directly via email.
If I don’t get a response again - I will scratch that company… :-X[/quote]
Yeah I get that feeling as well, which is why I am looking at other options again and using a Z-wave blind module.
I think I might settle on the HC China LTD company & HT-100 system. They mainly offer 12V DC motors but they have got a 230V AC motor which I would prefer. It will cost more $ but it will be quieter and I can hide the wires better in the wall.
They have some decent looking IR receivers / wall controllers and remote controls as well. They also have RF remotes. I can buy them locally in the UK, should be fairly easy to wire in the Duwi module. Their guys can speak English and I understand what they are saying and their 2M track
(DC Motor) is only 105 GBP
Got this email back from NWD abfter 4 days, I think Im gonna pass :slight_smile:
Hello,
I AM Q Li ,
Ok you want a NZ-C01 US for test.
yes , we also have track that fits this motor .
BUT now we only have 220V for China ,if you want to use in USA,You should be a transformer , to 110V.
I will send products to you By UPS ,and To pay the freight
THANKS
Hello folks in this topic !
some solution for integration of www.remotecontrolcurtain.com ?
I have one running and I’m trying to put zwave control in that.
I was speaking about with Shady, but he is out for a time…
my doubt is if the only solution is install 2 evolve lfm-20 controllers ( one for up and one for down) (is a roller shade)
or if exist one controller with the 2 functions…
thanks !
[quote=“Piwtorak, post:67, topic:173020”]Hello folks in this topic !
thanks ![/quote]
I am not familiar with the Evolve LFM-20 as I am based in the UK, however it looks to be a simple ON/OFF relay switch. I would think you would need two of them. You might be better using a proper Z-wave blind controller like these ESI ABMHZ modules:
http://www.smarthome-products.com/c-64-motorized-blinds-and-drapery.aspx
Have you tried contacting CurtainCall for help?
thanks Cw-kid !
I emailed to Tony in curtaincall. he sold for me the curtain…
back to the subject of evolve…it has a yellow wire… this yellow wire is not the common wire I need to runs the curtain…
I plug the common in yellow and up and down in each blue wire.
if this is not correct, what the function of the yellow wire in lfm-20 ?
thanks !
[quote=“Piwtorak, post:69, topic:173020”]thanks Cw-kid !
thanks ![/quote]
I dont think the yellow wire has any function.
The blue wires are used for the relay imo. I think it should state that in the directions it came with.
Flo
The user manual for the Evolve LFM-20 can be seen here
The wiring diagram is not that clear.
I think the yellow can send a command to a switch and turn on something.
would be very good if there was a dry contact with a common wire. giving 2 options only changing the contact for a side and another with zwave enable for sure… :slight_smile:
The yellow wire Is for adding auxiliary switches, for 3-way and 4-way control. Like in a hallway you can have a switch on either end controlling the same light, same concept but accomplished with a low voltage trigger on the yellow wire.
I think these are the aux switches:
http://www.smarthome-products.com/p-170-homepro-as101-z-wave-3-way-companion-switch.aspx
Here is a post from someone putting it all together:
http://forum.micasaverde.com/index.php?topic=10201.0
Hi CW-Kid,
Cracking job on this (and others).
Did any one get it up and running? would love to know if any one here in the UK has a working motorised curtain with zwave.
I shall watch with a keen eye ;D
No I never made a purchase in the end I got side tracked with other little projects that took up the cash. Still on my todo list.
we manufacture Z-Wave native tubular and drapery motors
contact us at info@zwavemotors.com
[quote=“zwavemotors, post:76, topic:173020”]we manufacture Z-Wave native tubular and drapery motors
contact us at info@zwavemotors.com[/quote]
Do you have a website with product details?
Which country are you located in?
We are located in the US. Contact us for pricing and technical info
try this website: www.z-wavemotors.com
this can help someone…
http://forum.micasaverde.com/index.php/topic,4811.msg112181.html#msg112181
Although this topic has been silent for a while I’m quite interested if someone found a good solution.
My idea is to use a fibaro roller / shutter to control the track.
I found this quite affordable track on aliexpress but the seller couldn’t tell me if it’s possible to hook up an external controller. This track comes with a wired remote so my guess would be that it should be possible but without the wiring diagram it’s hard to say for sure.
