Aeotec Multisensor ZW100-A (Parameter 49)
Hello,
I’m trying to set the Parameter 49 as per specifications, see attached screenshot from the documentation.
When I set it to 0x033902, this should be 82.5 F, instead of the default 82.4 F, I get in the logs
02 11/29/17 22:49:13.353 JobHandler::Run job#32 :cfg #37-0 p49 dev:182 (0x12e9e60) N:37 P:13 S:0 Id: 32 is 39.234377000 seconds old <0x76249520> 04 11/29/17 22:49:13.969 <Job ID="32" Name="cfg #37-0 p49" Device="182" Created="2017-11-29 22:48:34" Started="2017-11-29 22:49:13" Completed="2017-11-29 22:49:13" Duration="39.850724000" Runtime="0.616403000" Status="Successful" LastNote="SUCCESS! Transmit was OK" Node="37" NodeType="ZWaveMultiEmbedded" NodeDescription="Motion Sensor"/> <0x76a49520> 02 11/29/17 22:49:13.970 JobHandler::Run job#33 :cfg get #37 p49 dev:182 (0x12ea000) N:37 P:13 S:0 Id: 33 is 39.851204000 seconds old <0x76249520> 04 11/29/17 22:49:15.072 <Job ID="33" Name="cfg get #37 p49" Device="182" Created="2017-11-29 22:48:34" Started="2017-11-29 22:49:13" Completed="2017-11-29 22:49:15" Duration="40.952007000" Runtime="1.100859000" Status="Successful" LastNote="SUCCESS! Response command received" Node="37" NodeType="ZWaveMultiEmbedded" NodeDescription="Motion Sensor"/> <0x76a49520> ... 01 11/29/17 22:49:16.533 ZWaveNode::GetSetConfigurationIsEqual node 37 set 49 to 211202 but it's 210946 <0x76249520> 01 11/29/17 22:49:16.534 ZWaveNode::config_SetUserConfig node 37 failed 0 jobs 7 <0x76249520>
210946 = 0x033802
211202 = 0x033902
It behaves just like it would ignore the set request that is successful in job #32.
I tried also setting Property 48 to 1, but it didn’t help. Does anybody have any information about how to do it? Note that Property 252 is 0.
Any help is appreciated.
Thanks.
