Aeotec LED Bulb
I just received my LED RGBW bulbs from Do It All Tech, for more info about the product http://doitalltech.co.nz/product-details.html#cid=1167257
I would like to know when Vera is going to support the RGBW in the device.
Download the RGB controller plugin. It works well
Hi, I’m interested in buying the Aeotec LED bulb, but have one question.
If you install the bulb in a light socket which also has a light switch, can you turn on the light from the light switch or only control the light bulb from the vera.
Thanks in advance.
No you can not, the switch has to be on
