Does anybody have experience with the new Aeon Recessed Door sensor?
I have a 4in1 but that one is really bad. So is this product better?
I have 11 Aeon Door/Window sensors, and 4 of the Recessed.
I only have 1 of the 4 and 1, and have been disappointed in them. Mine actually started smoking and got really hot when removing the batteries and needed a replacement.
With the contact sensors though, I think they are really good and have worked flawlessly.
Some issues:
Overall, I’m happy that I don’t need to see the stick on sensors on the doors…and would recommend them to anyone whom wants to drill the hole.
Can it be used on say a bedroom door (I assume by drilling a hole in it)? Seems like if it can, it’s better than the alternative of an external door sensor.
Ya, just angle toward the inner wall ever so slightly when you drill. I got too close to the drywall and when i drilled up and it cracked above the door when I drilled straight up. A little spackle and paint will fix it up, but just my learning experience on installing #1 of 4.
Also, make sure you have enough ceiling space to drill the top hole in the door. I drilled a closet door with only 4 inches clearance on the top in the side instead.
Pic of my learning experience in the bathroom:
[quote=“AgileHumor, post:4, topic:179066”]Ya, just angle toward the inner wall ever so slightly when you drill. I got too close to the drywall and when i drilled up and it cracked above the door when I drilled straight up. A little spackle and paint will fix it up, but just my learning experience on installing #1 of 4.
Pic of my learning experience in the bathroom:[/quote]
I think you installed it backwards for what I would have done. I have always seen the unit installed int he door and the magnet on the frame. Then you cant see the screws and bigger base. What do the instructions show?
[quote=“integlikewhoa, post:5, topic:179066”][quote=“AgileHumor, post:4, topic:179066”]Ya, just angle toward the inner wall ever so slightly when you drill. I got too close to the drywall and when i drilled up and it cracked above the door when I drilled straight up. A little spackle and paint will fix it up, but just my learning experience on installing #1 of 4.
I think you installed it backwards for what I would have done. I have always seen the unit installed int he door and the magnet on the frame. Then you cant see the screws and bigger base. What do the instructions show?[/quote]
By mounting the main body (transceiver) in the door, it now becomes a moving transmitter. While the movement could be as little as 4 feet from open to close position, it might be enough to mess up the z-wave routing if the device is on the fringe edge range of its communicating neighbor in the mesh. Hence why they recommend that you mount the magnet on the door so the transceiver can stay stationary.
