Aeon multisensor 4-in-1 notifications *solved*
Hi!
I just bought an 4-in-1 multisensor.
I use Vera Alerts so I get push notifications, and it works for other sensors.
I dont get any notifications from the 4-in-1 multisensor.
I set the temperature values to send notifications under temp 15 and above 25 degrees.
Whats wrong?
Did you run the Configure Notification tab in Vera Alerts after adding these notifications ?
I have checked that, and it is ok.
But now it works suddenly.
You missed the point.
Opening the Configure Notifications fixed the problem!
Even if you do not change anything … you must open this tab when every you add/delete/modify a Notification in Vera, so that Vera Alerts is in Sync with Vera.
Ok, now I understand.
