Aeon multi sensor temperature in Fahrenheit?
I have just finished installing my Aeon 4-in-1 multi sensor on my Vera Lite, but the “_4 in 1 sensor (temp)” device shows the temperature in Fahrenheit (77) instead of Celsius. The Vera is set to Celsius under settings. My other thermometers shows the values in Celsius.
Is there a device setting for what scale to use?
According to the following (read the preceding posts as well), this depends on the interface:
http://forum.micasaverde.com/index.php/topic,3831.msg86150.html#msg86150
However, in here, it reads at one point, “The unit is fahrenheit of US version, other versions are Celsius.”
https://www.google.ca/url?sa=t&rct=j&q=aeotec%20multisensor%20celsius%20fahrenheit%20&source=web&cd=3&cad=rja&ved=0CDYQFjAC&url=http%3A%2F%2Fwww.smarthus.info%2Fsupport%2Fmanuals%2Fzw_sikkerhet%2Faeotec_multisensor_tech.pdf&ei=Gg5IUuCdGerB4APd2IGQDw&usg=AFQjCNH-u2DS2ieSS3QPmi7hWJy61Ty2WA&sig2=LpG6VRJz4wXPLV59iVeAJw&bvm=bv.53217764,d.dmg
When I configured mine, it showed Celsius automatically.
[quote=“Ds514, post:2, topic:177133”]According to the following (read the preceding posts as well), this depends on the interface:
When I configured mine, it showed Celsius automatically.[/quote]
Hmm. The 4-in-1 sensor is bought from Vesternet and should be a EU version. It also works with my European Vera and I have flashed the EU FW, so I do not think this is the cause.
Maybe the unit is showing C but is off by 60-70 degrees?
in UI5 click the clock right upper corner and check the page that temperature readout is in metric system.
Yes, that was what I meant with Celsius under Settings (Settings → Location → Temperature format).
Maybe try toggling to fahrenheit and then celsius again, being sure to save each time.
