Aeon Multi Sensor - Anybody else have one just quit?
I’ve had this thign workign with my Vera Lite UI6 for many months. I have the motion turned off and only use it for light level and to observe temp/humidity. I use the light level to turn on certain lights if it is dark outside (I look an hour before sunset). Worked great…until now. I just noticed one day that I had lights on way too early. I assumed the batteries were dead. Replaced the batteries…and then the fun began. It seems to send results sporadically. So, I removed it, then I had a real hard time finding it again. I’ve tried everything over and over, fresh batteries, USB, etc. I still can’t get it to work right. Just wondering if anyone else has had one die. I hate to spend the money to buy a replacement since I only use it for the one function. I may just check the weather string from Weather UNderground for “Mostly Cloudy” instead.
Tony
