Aeon Mini Remote wrong Scene numbers?
I have Aeon Labs Remote control (DSA03202W-ZWUS). I’m using it with Vera Lite running latest (1.7.690) firmware.
Remote has 4 scene buttons. I had no issues with button #1 which corresponds to Scene 1.
I created scene in Vera mapped to remotes scene number 2. Nothing.
I created another scene in Vera mapped to remote’s scene number 3. Now when I press button #2 on remote it thinks it’s scene #3! :o
I tried other scenes (0 and 4) but it seems that only 1 and 3 work. Again Scene one is mapped to button #1 and Scene #3 is mapped to button #2 for some strange reason…
I’m completely confused… Anyone seen this issue?
Thats because there are actually 8 buttons on that device :slight_smile:
1 is the upper left
2 is upper left long hold
3 is upper right
4 is upper right long hold
5 is lower left
6 is lower left long hold
7 is lower right
8 is lower right long hold
Delete the device and repair it to your vera, make sure you let it sit for 3-5 minutes after joining it to the Vera before trying program it, if you are lucky it will populate the 8 buttons for you. If not, make sure you select that it has 8 buttons and use the mapping table above.
[quote=“shallowearth, post:2, topic:189235”]Thats because there are actually 8 buttons on that device :slight_smile:
1 is the upper left
3 is upper right
5 is lower left
7 is lower right
Delete the device and repair it to your vera, make sure you let it sit for 3-5 minutes after joining it to the Vera before trying program it, if you are lucky it will populate the 8 buttons for you. If not, make sure you select that it has 8 buttons and use the mapping table above.[/quote]
That’s awesome! I didn’t realize about long hold :slight_smile: Now everything works and I didn’t have to delete or repair.
Now I’m trying to add second remote, and it’s not working for some reason (remote won’t reset) but that’s another story…
