Aeon micro switch wont report status [SOLVED]
I have a new micro swithc from Aeon DSC26103-ZWUS. When I activated through Z wave it works perfectly, when I use the switch it will also work but it will not trigger any scenes in vera or send a Zwave command. What can i do ?
[UPDATE]
I solved this by configuring parameter 80 to 1
Hope this helps
i add the parameter 80 to 1
however its only work for couple days
then it’s not reporting anymore
please help
