First post - go easy please. I’m not sure that my issue isn’t an issue with proper scene/triggering logic, or if there is a hardware limitation with this subject dimmer.
My master bathroom has 14 vanity lights, which, when they are all on, they will nearly give you a sunburn. I don’t mind that during the day, but when going for a potty break at 3am, it’s stroke-inducing.
Is it possible to set up a scene that has the module turn the lights on to, say 10%, between certain hours, when triggered by turning the existing switch on?
When I flip the switch on the wall, it seems to go to 100%, or off. I’ve set up a scene that turns the dimmer on at 10%, triggered by the same dimmer being turned “on”. But, when I turn the switch on, the lights are 100% for a few seconds, and then they adjust down to 10%.
I’m guessing that this is not the proper way to have the dimmer default to something other than a welder’s torch brightness setting.
I’m using a Vera lite (firmware 1.5.622). The label on the dimmer (PN the subject line) indicates it is a 2nd generation.
I’m afraid that what you desire is not configurable in the DSC27103-ZWUS In-Wall Micro Illuminator Dimmer. The directly connected switch will always turn it on as you describe.
Options that may work for you:
a) Use a Aeon Labs Minimote to activate a scene that sets the desired level.
b) Use a motion sensor like the Schlage RS200HC Motion Sensor in combination with a Scene/PLEG that only operates during the desired hours. The lights become automatic and there’s no need to touch the switch or have a stroke.
c) Replace the directly wired switch with a wall mounted controller like the Evolve LTM-5 Accessory Switch that controls the DSC27103-ZUS via scenes.
Thanks for the reply and the links. That’s unfortunate - and one of those things one doesn’t think asking/researching until after installation. It’s too easy for a noob like me to assume the hard switch input could be used to control a scene. Fortunately the only one I bought (so far) is for my front door - where this isn’t an issue.
Are there similar in-wall controllers that would permit the existing toggle light switch to activate a scene rather than (or in addition to) simply going 100% on off?
I think the Fibaros offer this, but they are not available in the U.S, yet.
