aeon led bulb help - blue standby LED control?
Hi all,
not sure if anyone will be able to help me out with this one, i’ve read the documentation for the aeon led bulb and can’t seem to find any variable to achieve what I’m after.
my story goes, Iv just put one of these bulbs into our bedroom (seems harmless enough) but I had to turn the thing off at the switch last night as the blue standby led is way to bright!
does anyone know of a way i can disable this led or does it have no control?
if not ill just put in an in wall dimmer and replace the standard lights again. just thought id check before i use up my dimmer as i was planning on using it elsewhere.
cheers,
adam
