Hi everyone,
For the past couple of days I get sporadic LuaUPNP reboots of my Vera Light. The error code is 139.
I finally figured out that the reboot always happens when Vera tries to poll my new Aeon Labs Sensor. Also, when I press configure now the system also restarts.
Here are some log files (node 29 / ID31 is my Sensor).
08 06/20/12 20:00:48.112 JobHandler_LuaUPnP::AlarmCallback Ran scene:1 Thermostat Poll (automated) / timer:5MinPoll next at 1340247948 now 1340247648 <0x2b25f680>
02 06/20/12 20:00:51.343 [33;1mZW_Send_Data node 26 USING ROUTE 255.112.75.184[0m <0x2b65f680>
06 06/20/12 20:00:52.612 Device_Variable::m_szValue_set device: 28 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: [35;1mCurrentTemperature[0m was: 71 now: 71 #hooks: 2 upnp: 0 v:0xba4f48/NONE duplicate:1 <0x2b25f680>
02 06/20/12 20:00:54.614 [33;1mZW_Send_Data node 26 USING ROUTE 255.112.75.184[0m <0x2b65f680>
02 06/20/12 20:00:57.903 [33;1mZW_Send_Data node 26 USING ROUTE 255.112.75.184[0m <0x2b65f680>
06 06/20/12 20:00:59.351 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mLastWakeup[0m was: 1340245721 now: 1340247659 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b25f680>
02 06/20/12 20:00:59.352 [33;1mZWaveNode::Wakeup did a poll for 29 5813 seconds interval 10800 existing (nil) heal (nil)[0m <0x2b25f680>
02 06/20/12 20:00:59.353 [33;1mZWJob_SendData UPDATE MANUAL ROUTE 29=0xb53527[0m <0x2b25f680>
02 06/20/12 20:01:01.355 [33;1mZW_Send_Data node 26 USING ROUTE 255.112.75.184[0m <0x2b65f680>
06 06/20/12 20:01:02.632 Device_Variable::m_szValue_set device: 28 service: urn:upnp-org:serviceId:HVAC_FanOperatingMode1 variable: [35;1mMode[0m was: Auto now: Auto #hooks: 0 upnp: 0 v:0xc30098/NONE duplicate:1 <0x2b25f680>
02 06/20/12 20:01:04.633 [33;1mZW_Send_Data node 26 USING ROUTE 255.112.75.184[0m <0x2b65f680>
02 06/20/12 20:01:07.893 [33;1mZW_Send_Data node 26 USING ROUTE 255.112.75.184[0m <0x2b65f680>
04 06/20/12 20:01:09.163 <0x2b25f680>
02 06/20/12 20:01:09.164 [33;1mJobHandler::Run job#617 :Wakeup done 29 (0xbe56e0) N:29 P:102 S:0 is 9.811134000 seconds old[0m <0x2b65f680>
02 06/20/12 20:01:09.165 [33;1mUPDATE MANUAL ROUTE2 29=0xb53527[0m <0x2b65f680>
02 06/20/12 20:01:09.165 [33;1mZW_Send_Data node 29 USING ROUTE 27.0.0.0[0m <0x2b65f680>
06 06/20/12 20:01:09.402 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:HaDevice1 variable: [35;1mCommFailure[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 v:0xb79b18/NONE duplicate:0
[7;36m2012-06-20 20:01:09 - LuaUPnP Terminated with Exit Code: 139[1;00m
---------------exited-------------
02 06/21/12 0:21:30.935 [33;1mZW_Send_Data node 26 USING ROUTE 255.240.229.196[0m <0x2b6a3680>
06 06/21/12 0:21:31.587 Device_Variable::m_szValue_set device: 12 service: urn:directv-com:serviceId:DVR1 variable: [35;1mChannel[0m was: DSCHD (278) now: DSCHD (278) #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bea3680>
06 06/21/12 0:21:31.588 Device_Variable::m_szValue_set device: 12 service: urn:directv-com:serviceId:DVR1 variable: [35;1mTitle[0m was: Paid Programming (No Rating) now: Paid Programming (No Rating) #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bea3680>
06 06/21/12 0:21:31.588 Device_Variable::m_szValue_set device: 12 service: urn:micasaverde-com:serviceId:HaDevice1 variable: [35;1mLastUpdate[0m was: 1340262991 now: 1340263291 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bea3680>
06 06/21/12 0:21:33.824 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mLastWakeup[0m was: 1340261359 now: 1340263293 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b4a3680>
02 06/21/12 0:21:33.825 [33;1mZWaveNode::Wakeup did a poll for 29 3871 seconds interval 10800 existing (nil) heal (nil)[0m <0x2b4a3680>
02 06/21/12 0:21:33.825 [33;1mZWJob_SendData UPDATE MANUAL ROUTE 29=0xc3cca7[0m <0x2b4a3680>
02 06/21/12 0:21:34.827 [33;1mZW_Send_Data node 26 USING ROUTE 255.240.229.196[0m <0x2b6a3680>
06 06/21/12 0:21:36.094 Device_Variable::m_szValue_set device: 28 service: urn:upnp-org:serviceId:HVAC_FanOperatingMode1 variable: [35;1mMode[0m was: Auto now: Auto #hooks: 0 upnp: 0 v:0xe1d0f8/NONE duplicate:1
[7;36m2012-06-21 00:21:42 - LuaUPnP Terminated with Exit Code: 139[1;00m
04 06/21/12 5:12:32.676 <0x2bc19680>
02 06/21/12 5:12:32.677 [33;1mJobHandler::Run job#226 :Wakeup done 29 (0xd7d030) N:29 P:102 S:0 is 18.681131000 seconds old[0m <0x2be19680>
02 06/21/12 5:12:32.678 [33;1mUPDATE MANUAL ROUTE2 29=0xebeabf[0m <0x2be19680>
02 06/21/12 5:12:32.678 [33;1mZW_Send_Data node 29 USING ROUTE 27.0.0.0[0m <0x2be19680>
06 06/21/12 5:12:32.894 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:HaDevice1 variable: [35;1mCommFailure[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 v:0xe91b28/NONE duplicate:0
[7;36m2012-06-21 05:12:32 - LuaUPnP Terminated with Exit Code: 139[1;00m
---------------exited-------------0
06 06/21/12 11:31:15.145 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mNodeInfo[0m was: now: 30,70,71,72,80,84,85,86,9c, #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b49b680>
06 06/21/12 11:31:15.146 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mPollSettings[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b49b680>
06 06/21/12 11:31:15.146 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mCapabilities[0m was: now: 82,156,0,4,32,1,R,B,RS,|48,112,113,114,128,132,133,134,156, #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b49b680>
06 06/21/12 11:31:15.147 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mNeighbors[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b49b680>
06 06/21/12 11:31:15.147 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mLastReset[0m was: now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b49b680>
06 06/21/12 11:31:15.147 Device_Variable::m_szValue_set device: 31 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: [35;1mAssociationNum[0m was: now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0
[7;36m2012-06-21 11:31:15 - LuaUPnP Terminated with Exit Code: 139[1;00m
[7;36m2012-06-21 11:31:15 - LuaUPnP crash[1;00m
01 2012-6-21 7:29:24 caught signal 6 <0x2c1a1680>
01 2012-6-21 8:17:40 caught signal 6 <0x2bdf9680>
As I said, this ALWAYS happens when I configure the device and also when I poll it.
Has anybody experienced similar issues?
Thanks for your input,
Flo
