Hi all,
I purchased this switch that reports energy usage. Is there anyway to have a log/report of the data?
Thanks.
Hi all,
Thanks.
The switch shows current usage and also keeps accumulating total energy usage until you reset it. However total KWh don’t show up on UI7. I set up HomeWave to show me that info and it works nicely.
A more-complex comparator circuit could work with drop of about 0.1 volts.
NOOR
Yes,
EventWatcher is going to be your friend here:
http://forum.micasaverde.com/index.php/board,75.0.html
the specific thread you are looking for is here :
http://forum.micasaverde.com/index.php/topic,30440.0.html
it will walk you through how to setup individual reporting on your smartswitch. it works for me!
Yes,
it will walk you through how to setup individual reporting on your smartswitch. it works for me![/quote]
Thanks, I will have to try this out.
