Aeon Labs Multi Sensor- Problems!
Goal: Sense activity in driveway, take snapshot using foscam outdoor ip camera and have it stream to vera alerts. As a plus I would gain outdoor temp and humidity.
What a pain in the but! Anyone who has gotten this sensor knows it doesn’t work right out of the box. You need to update the firmware of vera and the sensor.
Finally after I did that I got it to recognize but still several problems:
  1. Temperature is about 10 degrees off
  2. Humidity is 10% off
  3. Light seems to be 1000 or 0 in the web control panel but when viewing from vera mobile it shows up as (un)armed/(un)tripped sensor.
  4. Final constant false triggers mixed with constant no trigger on real motion
Anybody have any experience with this thing?
Dan
Yes. I got rid of it. There are a few threads with suggestions of decreasing the number of false triggers. None worked for me. But worth doing some research here on the forum
I got sick of fighting with mine and canned it. Maybe Fibaro will make one the works more reliably. ;D
