Aeon Labs Micro Switch trouble
I am having some trouble with the Aeon Labs Micro Switch. Everything is wired correctly and the z-wave function is working correctly but for manual operation I have to throw the switch twice to get it to turn on or off. Anyone have this problem or know how to fix it? Thanks in advance
Try changing the switch’s Change Mode. From the manual:
[b]Change Mode on the External Switch/Button Control[/b] ? The Aeotec Micro Smart Energy Switch G2 is set to be controlled via 2-state(flip/flop) external wall switch by default. Pushing and holding the button 6 seconds on the Micro Smart Energy Switch G2 will swap between this default mode and the momentary push button external wall switch mode.
That did it thanks!
