I have an Aeon Labs Aeotec Key Fob. I have set it up as a scene controller. Keys 1 through 4 function properly with a short button press. Keys 5 through 8 do not function properly with a long button press (nothing happens). My understanding is that you should be able to trigger 8 scenes. I can only trigger four scenes. Does anyone know what needs to be done to activate triggers for scenes 5-8? Eight scenes show under the control tab in Vera 3…
[quote=“Z-Waver, post:2, topic:182181”]Guide to setting up key fob with Vera.
Controlling scenes with the key fob.
Third party review with slightly different instructions.[/quote]
Spectacular!. Scenes 5-8 now work. I would have never figured that out on my own. It is not intuitive. The 3rd link is exactly what I needed. A little confusing to think through but I got it on first try.
Now all I have to do is tattoo the scene legend on my wrist!
Thanks Z-Waver!
OK. to get this to work on my VeraEdge running UI7 the trick was to add the device and then set the number of buttons to 8 and assigned the scenes. I still couldn’t make the secondary or extended buttons work, so I went into the scenes that I wanted to use for the extended buttons and added a trigger for Scene (1-4 button number that corresponds to the extended button) deactivate. Now they are all working! Nothing in the instructions I have found seemed to indicate that this was necessary, but it solved my problem.
