G’day,
Some of my smart switches change their external switch status from momentary to on/off (not sure what to call it). I then have to take the switch out of the wall and hold down the button for 6 seconds to change the external switch mode.
Is there a way for me to view what the external switch status is from the Vera gui and if there is, is there also a way for me to change the mode via the gui as well?
Thanks for the reply.
When using Parametre 120, do you know what the next part is, ie 1 byte hex.
Also, do you know if there is a way to see what the current configuration is via the gui?
Thanks.
