I have an Aeon Door sensor which I can pair with Vera2 fine and it works when within 20ish feet of the Vera. When I take the sensor to the door it doesn’t report back to Vera when the door is open/closed. I suspect the Aeon sensor is outside the range of the Vera so I placed a powered Appliance module between the Vera and the Aeon Sensor.
However, this still doesn’t work. Do I need to do something to the z-wave network to connect the Aeon sensor to the Appliance module then onto the Vera?
Looking through the forum I see that Vera updates it’s z-wave network daily so I thought leaving it a few days would solve the problem.
(Vera 2 european running the latest UI2 firmware)
