Hello,
I’m new to this and would appreciate any help int this matter. I recently got my sensor and siren and the setup I want is for the siren to be placed outside under the roof and the senor placed 150 feet away at the front gate. If the sensor is tripped when the gate is open the siren goes off. My problem is my siren seems to not work well at all unless it is right next to the vera2 unit. The sensor will not work that far even though it’s only 150 ft away from the siren (which Fortrezz website says it works as a repeater).
I want a similar set up for my backyard and if this can be worked out I will get more of the units. But when testing it on the backyard (detached guest room from main house) the siren does not work that far. I tried plugging in a wall lamp unit and that works find in the same outlet that the siren was plugged into. So why would the signal work for one thing but not the other?
Thanks for any ideas. I also emailed Mi Casa Verde support to see if they could provide help too.
Rick
