Alright - very new to Vera. Setting up 1st system at my new (& 1st) rental property. Honestly, all the posts are a bit overwhelming and I find myself getting more confused the more I read. So below I will describe my limited setup and what I’m trying to accomplish in the hopes some of you can throw me some suggestions. For infrastructure I have Vera lite and a DSC alarm panel.
From browsing, I see that Blue Iris DVR seems to be very popular, though I am trying to steer clear of leaving a laptop running 24/7 in my security cabinet. I also see network storage references, which is intriguing because I do have 2TB of drive storage incorporate into my wifi system (Apple time Machine Airport wifi router w/drives)
I only will have two cameras - one out back in a courtyard which can be hard wired to the system and some type of wireless camera at the front porch (must be wireless - no practical way to hard wire to system given location of two). I will have no cameras inside because I don’t want to freak out any vacation renters.
Ultimately what I’m trying to accomplish is: cameras which trigger via motion sensor and record streaming for a set time frame (say two minutes after trigger) what they see to a hard drive (which I will then backup remotely). Obviously, would also like to at least see/be alerted with still shots through vera. To view recorded streaming I will be able to access the router drives if necessary.
This al can be done with a hardware DVR… You don’t need to include Ver in this… I say that because I have not seen a good DVR that will work with Vera.
I install DVR and NVR’s for commercial and residential property.
Look at the Digital watchdog or the Digimerge DVR’s… all you need, and very reliable.
[quote=“jimpapa, post:2, topic:178291”]This al can be done with a hardware DVR… You don’t need to include Ver in this… I say that because I have not seen a good DVR that will work with Vera.
Look at the Digital watchdog or the Digimerge DVR’s… all you need, and very reliable.[/quote]
jimpapa…Thanks for your thoughts. Guess I am hoping to find a solution without adding anymore hardware than already exists or escalating cost beyond what is necessary. Already have the investment in Vera and an alarm panel, plus 2 TB of available networked drives. Seems that i should be able to find a solution with just adding cameras, having them record to the networked drives, and externally utilizing software to access what is recorded on the networked drives. The only way I see Vera incorporated is that I can get alerts on when camera is tripped (and records) via motion sensor.
[quote=“jimpapa, post:4, topic:178291”]Yes… you could do that … but the DVR’s I suggested will send alerts via Email… Some even do PUSH notifications to iPhones.
I am not saying you can’t try to pull off what your wish to do… I have just found this is not an elegant solution … in my experience. YMMV
I have a foscam on my vera and I use it for nothing… since false motions are high with the camera.
Some guys are having some type of luck… but my needs for reliable video could not be met with vera and cameras.[/quote]
So, do you have any suggestions on cameras for these systems? I need on POE and one wireless. Also, there are many dvrs in the ‘famillies’ you mentioned - what features do I look for for the ability for the e-mail/push notifications?
