We get lots of questions here in the forum, so I thought it might be interesting for a change to writeup what we’re doing in the Energy Monitoring space, a story if you will, to further spur adoption… or maybe just for amusement… 8)
I had @strangely visit my house over the weekend, and he got me thinking about home power management once again. I’d done some work a long time back, and have 14 channels of detailed power usage to go from, but hadn’t done any analysis in a long time. Things have changed around the house (like LED Lighting) so it was worth looking at again.
Power in Northen California is a constant ~$0.13 kWh, raising only slightly to ~$0.15 when baseline usage is exceeded. In some respects there isn’t much $$ incentive to fix usage, but it’s an interesting problem solving exercise and we’re heading into summer and AirConditioning will add up. Separately, it looks like OPower is actually going to turn it into a social game, so that’ll be an interesting experiment.
Anyhow, looking at the data collected, using UI4’s Flash-based historical energy charts on http://cp.mios.com, I could see that I had an Idle power usage of ~320W overnight, with only transient spikes from the fridges. If I could reduce this constant load, then I’d be in better shape overall.
I narrowed the list of larger consumers in my baseline, along with a few smaller ones that were easy to remove. What follows is a listing of these:
[ul][li]1x Charger for an older Harmony Remote I no longer use - 1W[/li]
[li]2x DLink Gaming Routers plugged in, but no longer used as I cutover to Airport Express units - 7W ea[/li]
[li]1x Logitech Revue - 12W[/li]
[li]1x Onkyo TX-NR807 Receiver in Ethernet-enabled standby mode - 58W (!!)[/li][/ul]
I made the following changes to start lowering my baseline usage:
[ul][li]I split the power rails in the AV Closet in an Always on rail, and a new Switched rail[/li]
[li]moved the Onkyo Receiver, Playstation, Wii and Xantech IR Repeater to the Switched rail[/li]
[li]moved the network switch, and Logitech Revue (for now) to the Always on rail[/li]
[li]attached the Switched rail to a GE Z-Wave Appliance Module[/li]
[li]added the Appliance Module to my Arming/Disarming scenes for the house[/li][/ul]
These were all bits I had on-hand, so with a few simple changes I’m now down to about 250W of baseline… Ok, that might only buy a few latte’s over a year long period, but it’s at least a start 8)
Next steps:
[ul][li]a) refining my Scene definitions to further reduce the amount of time that the Switched rail is enabled… turning it off “overnight”[/li]
[li]b) adding Scenes to turn it on if presence is detected in the Media room[/li]
[li]c) work out why the Onkyo chews soooo much power in Ethernet-enabled standby mode, or changing brand altogether[sup]*[/sup][/li]
[li]d) wait for the Brultech GreenEye model so I can further break out where my loads are[/li][/ul]
[sup]*[/sup] Perhaps I should be moving over to the Denon that @dreamgreenhouse just updated his review for, (either that or find a nice old solid NAD unit). Anyhow, here’s a link to the review that @dreamgreenhouse just revised/tweeted:
Stylish and environmental smart home design & build
