Advanced Events
I would like to set up a few more complex events. For example, turning on lights inside when a motion detector is activated, but only if it is after sunset.
I don’t see any ability to configure this type of event. Am I just missing it?
Will this be support when Lua is available?
Yes, you can all that, and almost anything, with the Lua module.
??? Where can I learn more about LUA?
I’m new here and just jumped in at version 283.
It then had an enable event/timer checkbox, but now in 292 it’s gone.
I do need this feature. At times my wife stays home (like tomorrow) and thus the schedule needs to be adjusted.
Before Vera, I used my PC to schedule and it adjusted the schedule based on the presence of a specific filename. (I’ve a script to toggle between the filenames “later” and “nolater”) It would be cool if LUA could accomodate that?!
Have Fun, Chris.
It then had an enable event/timer checkbox, but now in 292 it's gone.
It shouldn’t be. On my system there’s still the “Enabled” checkbox. Have you refreshed your browsre after the upgrade? What browser are you using? I’d need to take a look at it to see why it’s not working.
I’m using:
Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.0.3) Gecko/2008092510 Ubuntu/8.04 (hardy) Firefox/3.0.3
Shutdown and restarted it with same result... :-\
HF, Chris.
:o Ok, I see the enable checkbox for Events,
but not for Timers! ???
HF, Chris.
I, too, do not have an enabled check box for timers. It’s there for events, but missing for timers.
we’ll add it for timers too: http://bugs.micasaverde.com/view.php?id=259
