you can use
http://snippage.gabocorp.com/#download
and open the iphone page.
Works fine
[quote=“Maartenvt, post:21, topic:164326”]you can use
Works fine[/quote]
I tried this and when I click a room to control the lights, its starts a browser page in Safari and gives me an error. Are you sure this works?
[quote=“Chimpware, post:22, topic:164326”][quote=“Maartenvt, post:21, topic:164326”]you can use
Works fine[/quote]
I tried this and when I click a room to control the lights, its starts a browser page in Safari and gives me an error. Are you sure this works?[/quote]
Ahhhh, works as long as you do not put it back to Snippet View and leave it on full page view.
It should work even when its in snipped view. just play with it.
i have exactly the same size screen of the iphone and the links open also in the snipped view.
[quote=“Maartenvt, post:24, topic:164326”]It should work even when its in snipped view. just play with it.
i have exactly the same size screen of the iphone and the links open also in the snipped view.[/quote]
Tried a bunch of times, and could not get it to work in snipped view, but works great in non-snipped view, so thanks for the tip, I like it a lot.
at the right top you will see a cirkle, when you click on it it will be filled and the links wil be opened in the snap. when the cirkle is not filled it will open the links in your browser.
i am working with windows 7
[quote=“Maartenvt, post:26, topic:164326”]at the right top you will see a cirkle, when you click on it it will be filled and the links wil be opened in the snap. when the cirkle is not filled it will open the links in your browser.
i am working with windows 7[/quote]
You are correct sir, thanks, that worked.
you are welcome
[quote=“chairman_bubba, post:20, topic:164326”]oh my gosh. just got the json file format for the LUUP version of vera software.
it has changed completely and air4vera simply will not work. Much of the logic
is centered around parsing the json file and it will all have to be rewritten before it
will work.
So, if you are using 1.0.616 or earlier, this program should work.
My apologies to those of you who spent time on this with bad results.
So, do you think this kind of thing is worth my time going back and redoing it?
Just curious…[/quote]
Sure but how long will it take you do make it work! That might not be worth the time!
Hi chairman_bubba,
Very nice program.
running under Vista it gives a problem with the new security of vista.
a) solved this to run the application under admin account.
After install and configured it , the rooms are located in the screen , but the devices are not showed up.
Pls help
Best regards,
Marco
see my reply in
http://forum.micasaverde.com/index.php?topic=1699
I have a luup version of air4vera that is working.
One thing about this version is dimmers don’t work. I posted on the forum, but no one has responded. Can someone from MCV please help? See post ‘trouble with lu_actions’
Dimmers will go on and off with the ON and OFF buttons. I have temporarily set the slider to go all the way ON and not take a value less than 100 at this time. I can set a scene to turn the dimmers to a value, say 25%, then execute that scene and it works fine.
If you would like a copy, send me an email air4vera [at] gmail dot com.
Frank
