I have had better luck integrating this camera with my other Home Automation system called mControl.
I need a list of all the .CGI commands for this new camera, I’ve emailed the manufacturer. Or is there a way to query the camera to gain a list of these .CGI commands?
For example below is the driver code I wrote for this camera in mControl. I am not sure what the correct .CGI command is for StartRecording / StartStreaming.
EDIT: This URL is no good, it only display a static snapshot image in mControl not live video
This line is working however: to display the camera image in the mControl user interfaces.
The other thing the URL to display the image, brings up a small image, if you look at the camera in Media Center the image is too small, need to work out a URL to increase the image size.
I managed to integrate the camera OK in to my iPhone using the Foscam Surveillance Pro app and the Custom Camera option.
But no go adding it in to Vera !
3.3.2. RTSP stream
Our camera outputs are standard RTSP stream, you can use VLC Player or any other software
connected camera supports RTSP streaming RTSP streaming online viewing.
First of all you want to know the camera’s Web URL address, such as 192.168.1.128, RTSP is
the IP address of the camera port 554, the we network that corresponds to the URL address of the
camera is as follows:
Main stream:rtsp://192.168.1.128:554/ch0_0.h264
Minor stream:rtsp://192.168.1.128:554/ch0_1.h264
Audio stream:rtsp://192.168.1.128:554/ch0_3.h264
Specific steps for connecting camera with VLC:
Run VLC and select open network stream
I enter this in to the Add camera wizard in Vera and select Generic Camera. I left the user name and password fields blank, figured I didnt need them.
I then see the page in the attached screen shot Add-Device-Fail.jpg, Vera tries to display the image put it has a red X and does not work. If I right click this I can see the URL Vera has created for the image. Which is:
Then the URL works OK and the CAM image is loaded.
So I added the Camera anyways and I now have a new Generic Camera in Vera, if I click on the Spanner button, again I get a red X, see Generic-CAM.jpg attached, if I right click this area and select properties I can see a different URL which is:
Attached is the .CGI interface document for this camera.
It looks to me like there is no .CGI URL for directly streaming the MJPEG video stream. There is a /mobile.htm page that displays the MJPEG stream in a browser, but I need a .CGI URL to add in to Vera and mControl ?
There is a RTSP URL however for the H.264 stream.
The Cam manufacturer is no help either. Can anyone help get this camera working in Vera? Pretty Please! :o
Hi cw-kid
Did you manage to get this working? I have the same issue with this camera link → www.ipcamerasupplier.com/IP-Cameras/EF13ANM136
It shows up in Authomation and the PZT controls work fine, however, I dont see the video/image on the Vera interface.
Hi cw-kid
Please help if you’ve found a way.[/quote]
I don’t know exactly what I did but that AmoVision camera just started working in Vera one day. Its been working for several months now.
