I posted this to the Denon plugin forum, but thought I might get more attention here. I hope this is OK:
Since I was having issues with the current Denon plugin, I manually created a dimmer device to control the volume of my Denon S-900W receiver using the instructions from the Mios website. I also found this site that shows some lua code that can be attached to the dimmer device to control the volume. My problem is I am unsure where to add this code and was wondering if someone here would be able to help.
The example lua code I found is here: Show DENON AV reciever input in Text switch - Page 3 - Domoticz
Does someone know how I can go about doing this?
Thanks,
Andy
