I’ve been trying to add some HA04C modules to my Vera3 with no luck. I can’t find anything printed and when I try turning on and off while in “add device” mode they don’t get added. What am I doing wrong here? As usual the printed manuals are of little help.
Any controller can exclude a device even if it was not on the network. Most devices are tested at the factory and there are times when the device is paired but never excluded. So if a device is causing issues when pairing, excluding it first can fix the pairing issues.
