Adding a second Vera2. What am I missing?
The first vera is set as a switch to wireless router. Plug second vera into router and try to set it as a bridge using ssid and password, using (WEP)of router. The goal is to go go wireless on the second to the first but so far can not get the settings to stick. Thanks for any suggestions. Is there a trick to the sequence?
If the 2nd Vera is not connected to lan you will need to enable failsafe tunnels, select the wireless network you want to connect to by clicking scan networks. set your ip info and click save settings, then click the save up top.
Dont expect it to be a reliable connection.
JOD.
Got it to connect using your tip. Thanks - Now we will see how stable it is … so far it seems fine.
