Just took delivery of my vera plus. Under Add Device → Thermostats, I did not see an option for the honeywell. So I just added it as a generic z-wave device. It added to the network fine, but I am noticing that on the web interface the ‘inside temp’ is reading as 0.0. The set temp is fine and I can control the temp via the app or web interface.
Should the inside temp be working? Was adding the thermostat as a generic device the proper thing to do?
How does the interface look on your Vera? And Apps. basically I can only change the set temperature on my Honeywell TH8320ZW or toggle between heat/cool/off. It would be nice to be able to change the thermostat scheduled. (or just “resume schedule would be nice”)
