Had a handful of devices working flawlessly until I added 3 dimmers today; included them, none would configure, and then after heal, after reset, exclusion, nothing except one device (plug-in dimmer module) will configure (the 3 new dimmers are not re-included yet.
Did you give it 15 - 30 minutes and try another heal or two, before including/excluding again(reconfiguring the network)?
My suspicion is that the new devices are changing the network’s configuration and routing before the network has a chance to learn new appropriate routes. The error message indicates a communication issue that is common when Vera can’t reach the node because it is out of range or doesn’t have a good route. But, there are lots of possible causes which leaves lots of possible solutions.
For the quickest time to resolution, I would probably restore Vera and the Z-Wave network from last night’s backup. Then, assuming everything is working properly again, I’d include one dimmer at a time giving each one long enough to figure out the network or, if the network isn’t large, running a heal each time. But, I would not include another device before the previous one was working properly with the network.
I’d also perform a backup of Vera and the Z-Wave network after each successful include and configure, so as not to lose too much work if the next include breaks things and I had to restore again.
Thanks for the input. Unfortunately, was not able to fix the new network problem with a backup restoration after the new devices were excluded and powered off and several heals and individual stress tests.
I’m thinking a factory reset and then include each device individually unless that’s a bit excessive? (I can’t even remember how to do a hard reset on the Vera 3 - it’s only needed it once in almost 2 years…)
