I have my Plug-In installed and the AD2USB working like a champ as far as appearing in devices. Problem is, when I go to CHEAT SHEET to add my sensors, it is asking for variables I have no idea how to find.
Can someone please help me to better understand this process of perhaps point me toward other documentation.
Anything I have found appears out of date and is proving no relief to the issue.
For hardwired sensors and wireless sensors enrolled in the panel you can just add the zone # and name it, for wireless sensors that are not enrolled in the panel you can give it any zone number you want, name it and enter in the serial # found in or on the sensor, for the loop number look in the product manual to see what loop # you will need to enter, usually a 1 or a 2.
you might also try entering in the serial and loop # for wireless sensor that are even enrolled so they will respond even when panel is armed, I am not sure about this as i do not have any wireless sensors enrolled in my panel.
All of my sensors in building 1 are wired…only building (partition) 2 has wireless. Will try to apply some of this tomorrow. I had no idea the serial number would be relevant on a dummy magnetic contact switch like a wired door sensor. Will check out the panel manual as well to better understand the loops. For the zone, is that the partition or something I will find more about in the alarm manual. The wired sensor I am experimenting has an id of 02 on partition 1 keypad when the door is opened.
Thanks for the input…
