AD2USB Pin and trigger
Hello,
I got a vista 20 and Vera3 with the AD2USB, I programmed few scenes witch use a trigger, I found recently when, when the trigger did not get is signal, I had to put back the PIN and hit store. right after this everything trigger properly. I think this is happening when I unplug the AD2USB from the Vera, but i’m sure about the reason…
Did i miss something in the setup, can I script something to put the pin automatically?
There was a post a while back where someone has a luup code that runs at start up that stores the code, or what I do is use the advanced tab, detailed alarm state i think its called and enter my pin in the box.
http://forum.micasaverde.com/index.php/topic,18889.msg149348.html#msg149348
And… It does not work for me.
I followed the docs in the thread I opted above…PIN will not be loaded after restart.
I put this here because this post has over 150 views. So it looks like a bunch of us want to have this happen on our systems. But the discussion is in the link above… I have not heard back from those who got it working. They may be long gone.
[quote=“jimpapa, post:4, topic:177893”]And… It does not work for me.
I put this here because this post has over 150 views. So it looks like a bunch of us want to have this happen on our systems. But the discussion is in the link above… I have not heard back from those who got it working. They may be long gone.[/quote]
I’ve posted for help on this too. I have tried the code in the forum to no avail. My system is set up for 2 partitions, I wonder if that has anything to do with my issue.
well… here is What DOES work… (just tried this)
Create a scene called: store PIN
click on advanced
pick the device:
Ademeco Vista Alarm Panel, click ADD
Select Store PIN code and enter your PIN
I can verify that after reboot and you manually run this scene the PIN IS stored and available
I am trying to get this scene to run upon vera reboot and asked for help in another thread.
that just deals with running a scene on vera boot up. If that works (so far no) I will post a link to that solution.
In the meantime, i guess you could add this code to a scene as long as it runs first … so when you try to arm via a scene … you can make sure the PIN is stored…
terrific, thanks.
great approach.
Let me know how it works.
it WORKS:
http://forum.micasaverde.com/index.php/topic,22573.0.html
Change the {SceneNum=31} from 31 to your “store PIN code” scene
function DeferredScene()
   luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum=31}, 0)
luup.call_delay("DeferredScene", 15)
Yes! I copied your approach and it worked. This solves a big issue for me. THANKS!
Big help form RichardTSchaefer and RexBeckett!
