I got my ad2usb to connect to a pc via nutech gui and putty verified address 18, 1 partition. I connect it to my Vera 3 and can see the status on the devices and the logs. However when I send Arm/Disarm the alarm system does not get the commands. Need help not sure what else to try.
Did you enter the pincode and hit the store button? are you getting any errors? Another common problem is not activating the keypad address in the ademco programming from the keypad or having multiple keypads with the same address. Might want to have a look in the AD2USB sub forum in the plugins development section for more help.
thanks for pointing me in the right direction… I verified before that ad2usb was on address 18 I just checked it and somehow went to 20. I placed back to 18 everything working great
