Is it possible to program a Fibaro dimmer to come on only for a set amount of time before switching off automatically? Whether this is done by defining parameters or by using scenes doesn’t really matter. I could just do with it so it turns off automatically after a pre-set amount of time each time it is activated wirelessly.
The Fibaro relays (FGS211 / FGS221) have parameters #3 and #4 which enable this function for a programmable amount of time. These parameters don’t seem to appear in the dimmer (FGD211) documentation, so I can’t say if they work in the same way.
An obvious alternative is to trigger a scene when the dimmer switches on which simply delays and then turns the device off.
So yes, one way or the other, this should be straight-forward.
Do we take it that you got over your previous problem reported in a separate post with these dimmers?
First one is just using the Scene interface with a managed delay, second one accomplishes much the same using Luup code in the scene. Set up a trigger for the scene to be started by the dimmer being switched on.
