action with Timer 5 times to following
hello
I have a stage that I want to switch to PLEG
the stage in question triggers a siren in case of detection of tampering
shutter button:
detection mvt = on
virtual switch = on
device:
switch virtual present = status
provided that:
present = 0 and virtual switch
Action if detection mvt goes to 1:
the siren is ON for 40 sec
then OFF for 15 sec
then back ON for 40 sec
then OFF for 15 sec
against by, if in the meantime, present goes to 1
we stop the siren and actions
I do not see how to realize this with the PLEG
an idea please?
Using State Variables would be my suggestion.
@RexBecket has an example in the PLEG Basics guide.
thank you for your answer
I saw the pdf
by cons, I completely blocks on the actions …
should I use many timer?
thank you
I did a simple test with only 1 timer
but it does not work
In the Action for the Condition Go you should target your PLEG device for the StartTimer action - not Program Logic Core.
Also you should change the Condition Arret to stop it firing too early:
Arret !Toff and (Go; !Toff)
thank you
dizzy
seen that it works, I modified in connection with the initial application
is it possible to improve this PLEG?
