Accessing Vera remotely through the MiOS servers with UI7
I am trying to access remotely access my vera lite through the https API.
I can call the API’s without problem locally but when I go through the MIOS servers I get an ‘invalid user/pass’ when I use my current UI7 account from home.getvera.com. When I use my old UI5 account I do not get an error but my Vera controller does not return any information.
Is the following call still valid for UI7 controllers?
https://fwdX.mios.com/demovera/myvera123/30012345/data_request?id=user_data
UI 6/7 uses the newer platform and UI 5 uses the older one. They use different servers and API method. What version do you have?
UI6/Ui7 uses different servers and a different, more secure, authentication method. So a plain http call will no longer work. Check the plugin/app sub forums as the new authentication process is posted there.
I am using UI7. I search the forums on authentication but was unable to find a description that explains the remote request authentication for UI6/UI7.
I would expect that this is documented somewhere as it is for UI5 but I cannot find that either.
Maybe someone can post a simple example here?
http://forum.micasaverde.com/index.php/topic,24942.0.html
It wouldn’t have come up with a search because it talks about UI6, not UI7, but the protocol is the same.
That helps. Thanks!
